We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
I would very much like to create a workspace that has a particular note and the calendar in the sidebar to the right.
I have realized that on ios, there is no way to use a keyboard shortcut to pin the right sidebar, which makes this kind of “macro” impossible. It would be great if you could set a keyboard command to pin the sidebar, as opposed to only toggling it. Thanks!
