Keyboard Navigation Using Cmd + UpArrow or DownArrow
In Obsidian (as in other things like web browsers or documents), I regularly navigate within text using Cmd+UpArrow to go the top of a note and Cmd+DownArrow to go to the bottom of a note. For long notes/docs, way faster than scrolling
It seems that Obsidian has changed things such that this has stopped working and it’s driving me bonkers. I’ve noticed it for the last week or so and it seems to be Obsidian specific as these shortcuts still work fine in other apps (e.g. web browser, word processor, etc). Any ideas? Are there other shortcut keys? I’m using Obsidian 1.10.1 on MacOS 15.6.1.
Did you try in sandbox vault as well?
Sandbox vault
Obsidian’s sandbox vault is a feature that lets you explore various functionalities without affecting your existing data. This vault is helpful both as a learning tool and for debugging issues. It helps determine if a problem is caused by a plugin, theme, or the application itself.
The sandbox vault is not available on mobile devices. However, you can download a copy from the Obsidian Help repository for use on mobile.
Opening the sandbox vault
You can open the sandbox vault in multiple ways. In all cases, it opens separately from your current vault.
Left Sidebar
  1. Expand the left sidebar ( obsidian-icon-side-bar-left.svg > icon ).
  2. Next to the vault switcher, press the Help icon ( obsidian-icon-help.svg > icon ).
  3. Select Open next to the Sandbox vault option.
Command Palette
  1. Enable the command palette core plugin.
  2. Open the command palette.
  3. Search for Open sandbox vault.
  4. Press Enter or select the item to open the sandbox vault.
Close the sandbox vault
To close the sandbox vault, close the Obsidian Sandbox vault window.
https://help.obsidian.md/sandbox
moved to help for not following the BR template
