Get my obsidian vault to unfreeze. It will work fine then all of a sudden will freeze for a few minutes. I just moved a fairly large vault inside this vault so I know that is the problem. I’m just trying to get it to work now.
something is indexing your vault (omnisearch plugin?) or you have some markdown file that is full of base64 images…?
make a copy of community-plugins.json file by renaming it to community-plugins.json.bak and restart obsidian (with no community-plugins.json in the config folder) to rule out some plugin (indexing) issue, then if you still continue to have the freezing, you need to hunt down the file(s) that cause the issue
