It is not working on ios17.2 and ipados17.2
Hello there,
I hope you’re doing well. I’m reaching out because I’ve encountered an issue after updating my iPad and iPhone to version 17.2.
Following the update, the application is not functioning properly. Specifically, it launches successfully, but then it remains stuck on a black screen. Despite my attempts to resolve the issue, including deleting my vault and performing a reset, as well as uninstalling and reinstalling the application, I haven’t seen any improvement.
(I just saved my data in phone storage and used obsidian-git plugin)
I kindly request you to investigate this issue at your earliest convenience. Your prompt attention to this matter would be greatly appreciated.
Thank you for taking the time to read this.
By “performing a reset” do you mean you restarted the phone/tablet?
If you create a new empty vault, does it work?
