Open a template through templater to create new note and displays the code of property instead of properly format list of property.
Loaded template to edit it and it looks fine.
Any ideas?
Hi can you paste the template here in a fenced code block like this:
aliases:
status:
created: '<% tp.file.creation_date("YYYY-MM-DDTHH:mm") %>'
tags:
# <% tp.file.title %>
and include exactly how you are applying the template to a note. Typically it would be running the Templater: Open insert template modal command
and choosing the template name:
Maybe a screenshot or two could help here as well.
