Issue with Executing Advanced URI Using QuickAdd in Obsidian
Hello everyone,
I’m encountering an issue with the QuickAdd plugin in Obsidian and need some assistance. I have set up an Advanced URI to trigger a specific action in QuickAdd, but when I click on the URI, nothing happens.
Here’s the URI I’m using:
obsidian://advanced-uri?vault=LucasCofre1.4.1&choiceid=2eb27d4b-e1f9-47ee-8419-e85f4d49b581
This URI is meant to trigger an action named “NotaPassageira-criação” that I have configured in QuickAdd. The choiceid corresponds to this action, and the vault name is correct.
However, when I click on this URI link, there is no response or action triggered in Obsidian. I have checked the following:
  • The Obsidian app is open and running.
  • The choiceid matches the configuration in QuickAdd.
  • I am using the latest versions of both Obsidian and the QuickAdd plugin.
  • Permissions for opening links between applications are allowed on my operating system.
Despite these checks, the issue persists. I’m unsure if I’m missing a step in the setup or if there’s a technical glitch. Any insights or suggestions on how to resolve this would be greatly appreciated.
Thank you in advance for your help!
Best regards,
Lucas
How did you get the choiceid? Did you use the Advanced URI command to copy this?
Hmm… I hadn’t thought of that. i will try =)
