I’m trying to select multiple notes and drag and drop them into either a) the Finder or b) Scrivener. If the finder, I want it to simply make a copy of the notes into new text files. Or if Scrivener, I’d like to be able to create new Scrivener entries with each Obsidian note’s text in it.
Is this possible? I want the text inside each note to simply go where I drag it… I don’t want to do this note by note, I want to be able to do this with multiple notes.
Of course I could go into the underlying vault folder myself, but then I would have to find each note individually that I wanted by opening each file.
I want to be able to pick the notes from Obsidian… select all the ones I want, and then have the underlying files come with them when I drag the notes.
