I was using dynalist and there I could search for unchecked items that I created like “is:checklist -is:completed” in search bar. Is something like this possible to do in Obsidian?
You could search for "- [ ]" – this would show all uncompleted items. I’m not sure if there’s a helper that’s been introduced recently that’s easier, though.
@justindirose is right.
A more robust but more complicated search using regex can make sure all the details of the task line are included in the results.
I can’t recall the exact query off the top of my head, but I built it into the Vantage plugin, which gives you a GUI for complex searches.
thank you.
