  1. Searched the community and official third-party plug-ins
  2. Searched the forum, but the phrases “at sign” and “context” are so broad that the results are irrelevant
I’d love to be able to add a context tag and have it react the same way as adding a normal tag (i.e. autocomplete, dropdown, styling). I know I can accomplish this with regular tags, but my workflow would benefit from having tags AND context. Does an unofficial plug-in exist that adds this behavior?
Can’t you use nested tag
@location/work
@location/home does the job ?
I could, but that wouldn’t have autocompletion or style differentiation
I don’t know of one, although a variety of GTD plugins exist that may do this as a sub-feature.
The simplest workaround, though, is probably just to do:
#at/home
#at/store
#at/ might be complicated to type, but you could then set up a text expander to turn @@ or similar into #at/.
Yeah, that may be the best solution at this point. Thanks all!
