Is it possible to transform dataview results from within a query?
I have a query which produces a table. In addition to the normal ID, it also has a date field, and other fields. I would like to be able to display the date as a link, for example.
here’s a little query that does it in two different ways:
TABLE "[["+file.name+"]]" AS datelink
FROM "journal"
LIMIT 5
TABLE link(file.name) AS datelink
FROM "journal"
LIMIT 5
Second one is probably a bit more elegant.
Here I just pulled a few files from my journal and used their names to act as date strings. You can coerce between date and string with date() and string() functions if needed.
https://blacksmithgu.github.io/obsidian-dataview/reference/functions/#linkpath-display
