Hi all, I’m unfamiliar with Obsidian APIs and codemirror stuffs, so any information is appreciated. Currently, I’m using the cm-editor-syntax-highlight-obsidian plugin for my editor mode syntax highlighting, but finding some limitations:
- Some of my favorite langauges (e.g. FlowJS and Racket are missing
- The CSS color theme I made for preview mode does not apply on the editor mode because editor mode uses codemirror highlighting while preview mode uses prism. This means that we have a different set of CSS class names to handle with.
Therefore, I’m thinking of making a new plugin that parse codes based on prism in order to be consistent with the preview rendering.
My naive plan for now is to:
- Capture the
onChange
event of HyperMD (codemirror) code block lines (with debounce). - When the line changes, take the text content of
.cm-active.cm-line
and feed it into the prism manual mode, which takes a string and returns HTML string produced. - Replace the current line content with the newly produced HTML string.
Does this look practical? Any foreseeing (performance) issue? Or is there a far better way of integrating prism into codemirror editor using some codemirror APIs?
Thanks!
