Is it possible to drag and drop images from a note into an excalidraw drawing open next to it?
I would like to drag and drop images from one note into a neighboring excalidraw drawing, inhabiting the same tab, using only my stylus.
I know it’s possible to do this by copying and pasting the link
My question is: Is there a way to do this using only the mouse / stylus, via drag and drop?
When I try this, it doesn’t seem to work, and using the alt-, shift- or ctry key along with it doesn’t seem to make it work, either.
Is there a way to do this I am not aware of?
And if not - what might be the reasons for developers to decide against this functionality?
(Trying to get back into using Obsidian after a longer pause.)
If those things don’t work then the answer is probably know. I don’t know the developer’s reasoning, but maybe it was too hard to do, or maybe it didn’t occur to them. Or maybe it’s a bug. You can check the Issues tab of the plugin’s GitHub for a relevant feature request or bug report. If there isn’t one, you could post a feature request there.
