So, I want a file to have a link that changes depending on whether I’m using a mobile device or not. Basically, something like:
if (.is-mobile) {
dv.paragraph([[mobile view]]);
else {
dv.paragraph([[normal view]]);
Is this possible?
Nevermind, figured it out! I skimmed through the Excalidraw plug-in, found the part that optimizes for mobile, and got this to work:
if (document.body.hasClass("is-mobile")) {
dv.paragraph("mobile");
else {
dv.paragraph("not mobile");
Yaaay!
system
Closed
3
