Is it possible to cmd+o and then select the note add a # + header and jump directly?
Or is there a plugin that makes it possible?
That’d be so speedy :slight_smile:
You can use this plugin. Replace hotkey Ctrl/Cmd+O to load this plugin’s command and press # to start searching header. But just a caveat, I don’t think you can select a file then select a header – u just have to search all header and select the file you intend (if you have same header title across multiple files/notes.
@efemkay Thanks so much ! I had it installed and enabled but didn’t work. The secret is to not use # but @ to jump to the symbols :slight_smile:
Thanks!
Okay. Just to cover the bases, it worked for me. I just run Quick Switcher++: Open command based on the plugin default settings. Hope that helps (additionally) :slight_smile:
my pop up modal box (Quick Switcher++: Open)
here’s my settings
