Is it possible to add a timestamp when a metadata is changing?
For example, I have a key with these values: to do, doing, done. Every time I change the value, it will automatically add a metadata with the current date as the value. For example, if I change from to do to doing, then the metadata will be:
time:
 doing: 2022-03-21
If I change from doing to done, it will be:
time:
 doing: 2022-03-21
 done: 2022-03-22
I guess I can manually add this, but is it possible to do it automatically? Perhaps using the MetaEdit’s API
You can def do this with the MetaEdit API.
I did something similar and explained it in this post, hope this might help you out :slight_smile:
What I did is basically add a :white_check_mark: emoji to my frontmatter habits to finish them off in my daily notes using a button (buttons plugin)
Because I want it clean and automatically with buttons since you can create them anywhere, there’s quite a lot to it.
You can check it out here:
