Is it best way organize my idea?
Hello, i am new at obsidian and studying with it functional. My idea is write game mechanics from games and organize them in cool view with graph view. I wanna when pressing on specific game i can see corresponding mechanic to this game. I made it in such way as described in two added images. Is it good option or it is possible make it better\easier? let me know pls people
I tried only creating folders because i dont know other ways how can i do it
The best way to organize is a way that works for you and your brain.
Don’t worry too much about getting it ‘right’ from the first go; You can easily change your whole setup later.
Experimenting with non-critical stuff like this is the best way to go
My own suggestions as a start;
Specific property
  1. Have a note for each game
  2. Give them a property called ‘mechanics’ or something and make it a list type
  3. Enter the mechanics as notes ([[Fishing]]) in the property field
Tags
  • Just tag the mechanics on their own (#fishing)
    OR
  • Nested tags (#mechanic/fishing)
Unless this vault is only for this, I’d suggest going with specific properties.
thanks, makes brain calmer
Adding to what dmantisk said with having each game on its own page and using properties, you can also create an Index page (or “Map of Content/MOC” as the kids are calling it these days), such as “Fishing Mechanics”, then link each game with fishing in it. You can do the same with, say, “Farming Mechanics” and link the games that have farming.
# Fishing Mechanics
## Fishing as the Focus
- [[Cat Gone Fishing]]
## Fishing as the vehicle
- [[Dredge]]
## Fishing as a sidequest
- [[Stardew Valley]]
- [[Breath of Fire]]
That way, each game would have a #fishing tag or property, but would also be directly linked by your Index page for fishing that lists all of them along with the type of fishing.
Obsidian also has Backlinks, which (when turned on) will show at the bottom of the page what links to them, so your individual games pages will also have an automatically-included link back to any Index pages you created.
thanks for idea
I am also fairly new to Obsidian, so my advice is to be digested with a grain of salt. Still, compared to other knowledge repositories I tried, the fascinating thing with Obsidian is the high degree of customization possible.
That comes with a learning curve and I think the best way is to start like you did.
Those other two comments are already all you need for a start.
One note per game, define properties that fit your needs:
  1. main classes: Mechanics, Color-scheme, etc.
  2. sub-classes: fishing, running, warm-colors, night-colors, etc.
Then adapt on the go.
Have fun doing it!
If you want, you can write the list of stuff you want to do, use Mermaid to arrange them in order (or any tool that can help you visualize how you want to do things), then you can do this and will feel more organized. Unfortunately, I’m not allowed to add links, so Mermaid(dot)ai is the website.
Here’s an example:
I want to organize game mechanics into a file so I can
easily click through qualities. Here are some qualities I am thinking about.
I could use a diagram or something that allows organized backtracking/breadcrumbs.
the game: Dredge
mechanics: fishing, moving boat, dredging up waste and maybe find treasure, talk to people
how will they be done: fishing requires so and so...
Either |Game/Dredge/Fishing| can be my structure or
|game -> dredge -> fishing| can be my structure.
How can I organize these files?
mindmap
  root((Game Mechanics))
    Games
        Dredge
            Fishing
            Talking to people
                When near an area
            Move boat
                Mouse?
            Programmming Language
                C#? C++?
        Stardew Valley
            Fishing
                Click with stylus?
            Plant trees
                Press button --button--
            Programming Language
                C#?
    Visual Techniques
      File map
      Make Sprites and More
        I added this because Stardew Valley has really cute pixel sprites
            Aseprite could be an option
            Pixelorama can be an option
            GIMP?
            Krita
Overall, I think your set up is fine, it’s just that you might fare well with some database structures and design. If it works as it is, I’m not hating one bit. My structures for my characters look similar to yours. I think it’s fine.
