Is Advanced Canvas plugin compatible with Semantic Canvas plugin?
There are features of both Advanced Canvas and Semantic Canvas that I would like to use.
But before I start migrating stuff to a canvas-based approach, I wanted to find out if the 2 plugins are compatible.
Has anyone tried to use these together? Did you notice any incompatibilities?
I’ve looked at the git sites for both plugins, the obsidian doc, and any other google site I could find that related to the plugins. But I’ve found nothing about their compatibility.
This sounds like a perfect thing for you to test out in a sandbox vault. Either the removable one from the help menu, or a more permanent one to be used by yourself to test various plugins, queries and/or concepts.
Having a sandbox vault to play around with I considerb to be very useful since it allows to this kind of “experimental” stuff without causing any effects to your personal vault(s).
@holroy - Yes, that was going to be my next step. But I thought if someone else had already tested this, it would save me a bit of time. :wink:
