[iPadOS] Clicking Outline in pinned right sidebar, then clicking in editor with mouse/trackpad, creates unintended text selection
  1. On iPad, enable the core plugin Outline.
  2. Open Outline in the right sidebar.
  3. Pin the right sidebar so it stays open.
  4. Open a note with multiple headings and body text.
  5. Place the cursor somewhere in the editor.
  6. Use a Magic Keyboard trackpad or an external mouse.
  7. Select any heading in Outline to jump to that section.
  8. Click somewhere else in the editor body text.
Y
A normal single cursor placement in the editor, with no text selected or jump.
A text range is selected unexpectedly in the editor, even though I only performed a normal click.
The selection appears to extend between a random cursor position and the new click position.
Obsidian Mobile v1.12.4 (Build 299) via TestFlight
iPad model: iPad Pro 11-inch (3rd generation) (MHQU3FD/A)
iPadOS version: iPadOS 26.3 (23D127)
Editor mode: Live Preview and Source mode
Reproduces in a new empty vault: Yes
Reproduces with Restricted Mode enabled: Yes
Obsidian version: 1.12.4 (299)
API version: 1.12.4
Operating system: iOS 26.3 (Apple iPad13,4)
Catalyst license: insider
  • This happens on iPad when returning from Outline to the editor using a trackpad or external mouse.
  • It does not happen when using touch only.
  • It does not happen when the right sidebar is not pinned.
  • It does not matter whether the heading in Outline was selected by touch or by pointer. The trigger is the pointer click back into the editor.
  • It reproduces with both a Magic Keyboard trackpad and an external Bluetooth mouse.
Possibly related issues:
  • https://forum.obsidian.md/t/ios-cursor-jumping-after-selection/107976
  • https://forum.obsidian.md/t/ipad-single-finger-trackpad-click-mouse-left-click-opens-right-click-menu-on-files-randomly/78857
Screen recording:
https://youtu.be/Oj969tU3TMA
The video shows that after clicking a heading in Outline, the next pointer click in the editor creates an unintended selection.
thanks for the detailed report
