Are you using iOS or Android?
[ X] iOS
[ ] Android
Is this a bug report or a feature request?
[ X] Bug report
[ ] Feature request
Shift-Tab does not reduce indent on ipad. No menu item to reduce ident either?
You can add both the indent and unindent buttons to the mobile toolbar, by default they are not on it.
I can confirm that Shift-Tab doesn’t work.
Should be fixed in 0.0.16.
