iPad: Obsidian frame rate capped at 30 fps (Safari on the same device runs at 60)
  1. Open Obsidian on an iPad.
  2. Turn on Restricted mode (Settings → Community plugins). Close the app fully and reopen it.
  3. Connect the iPad to a Mac. Open Safari → Develop → [iPad] → Obsidian.
  4. Run this line in the console. It counts animation frames for 2 seconds:
let n=0,t=performance.now();(function f(){n++;if(performance.now()-t>=2000){console.log(n/2,'fps');return}requestAnimationFrame(f)})()
  1. Open a website like example . com in Safari on the same iPad. Run the same line in that tab’s console.
Did you read and follow the Troubleshooting Guide? Yes
About 60 fps in Obsidian, the same as Safari. The iPad Air has a 60 Hz display.
Obsidian is capped at a steady 30 fps:
Where Result
Obsidian, Restricted mode ~30 fps
Obsidian, community plugins on 31.5 fps
Safari, example site, same iPad 61.5 fps
Each frame takes about 33–34 ms, with no spikes. That looks like a frame-rate cap, not slow work. Restarting the app does not change it. Low Power Mode is off. Accessibility → Motion → Limit Frame Rate is off.
Everything that animates is visibly choppier: scrolling, panning, and drawing.
Obsidian version: 1.14.4 (389)
API version: 1.14.4
Operating system: iOS 26.6.2 (Apple iPad15,3)
Plugins installed: 21
Plugins enabled: 5
1: BRAT v2.2.0
2: Fast Note Sync v2.4.0
3: Daystream v0.0.1
4: Tracker v0.0.1
5: Inky v0.0.1
I repeated the tests in the sandbox vault. Results persist.
  • Device: iPad Air (M3)
  • iPadOS: 26.6.2
  • This started in the last few days. Before that, the same device ran smoothly.
  • I think it began with the update to 1.14.4 Mobile (public release, October 5, 2026), but I have not confirmed that.
  • The 1.14 changelog lists no rendering changes. It does list text scaling with the system text size, Settings as a sheet, and Split View / Stage Manager sizing fixes. Could one of these have changed how the web view renders?
we’ll look into it
Create a new empty vault (default theme, no snippets, Restricted mode on).
Create a few folders and expand or collapse them in the file explorer.
With Excalidraw enabled in another vault, draw freehand with Apple Pencil.
Did you read and follow the troubleshooting guide?
Yes. Restricted mode, a new empty vault, reinstalling Obsidian and updating iPadOS (26 → 27.0.1) made no difference.
Smooth animations, as before. The rest of iPadOS is smooth.
The app loads and responds at normal speed, but animations look like they run at a much lower framerate (folder expand/collapse, UI transitions). It’s most noticeable when handwriting in Excalidraw. Excalidraw in Safari on the same iPad is smooth, so the issue seems specific to the Obsidian app.
Note that i have tested in a completely fresh vault as well.
API version: 1.14.4
Operating system: iOS 27.0.1 (Apple iPad15,7)
Language: en-GB
Catalyst license: none
Base theme: light
Community theme: AnuPpuccin 1.5.0
Snippets enabled: 6
Plugins installed: 12
Plugins enabled: 10
1: Banners v1.3.3
2: Force note view mode v1.2.2
3: Homepage v4.5.0
4: Iconize v2.14.7
5: Style Settings v1.0.9
6: Kanban v2.0.51
7: Dataview v0.5.68
8: Templater v2.25.1
9: Excalidraw v2.28.1
10: Tasks v8.4.0
The rest of ipadOS behaves like normal. Device is not warm, has plenty of free storage.
I can confirm. I was able to notice this in Inky (a TLDRAW based drawing addon). Strokes are not smooth and the all animations seem to be capped at 30 fps including obsidian native animations.
will be fixed 1.14.5. ETA unknown.
