- Mark a .base file as bookmark
- Create the view note widget on iOS 27.0.1
- Try to select the .base file on the view note widget
Did you read and follow the Troubleshooting Guide ? Yes
I’ve expected to see the .base file marked as bookmark on the view note widget and select it.
The .base file marked as bookmark does not appear on the list of the widget.
Obsidian version: 1.14.5 (387)
API version: 1.14.5
Operating system: iOS 27.0.1 (Apple iPhone18,3)
Language: en-GB
Catalyst license: none
Community theme: Minimal 9.1.4
Snippets enabled: 1
Plugins installed: 18
Plugins enabled: 13
1: Omnisearch v1.31.0
2: Auto Link Title v1.5.5
3: Style Settings v1.0.9
4: Quick Switcher++ v6.2.0
5: Admonition v12.0.11
6: Image Converter v1.4.6
7: Update modified date v1.5.4
8: Minimal Theme Settings v9.0.0
9: Kanban v2.0.51
10: Outliner v4.10.2
11: Symbols Prettifier v1.2.5
12: Recent Files v1.7.10
13: Templater v2.26.0
