Internal Links – Disable automatic append of Custom Display Text when using Relative Paths
With the setting “New link format” set to “Relative path to file”, when I insert a new Internal Link to e.g “Dogs”, it shows up like [[Animals/Dogs|Dogs]]. However, I would like to disable the automatic appending of the custom display text, so that it would instead say [[Animals/Dogs]]. Is this possible?
So far I can’t seem to find anything that would fix this in the options nor have I had any luck finding a plugin that would solve it.
