When I use the “insert markdown link” button to insert a markdown link in a note it doesn’t function as assume it should. The lost of files to link to is not presented and the file name is not put in the parens.
When I start with “[[“ I get a proper link, but “[[“ is two levels down on my virtual keyboard.
Not a terrible big deal but the button would be slightly more convenient.
If you have Settings > Files & Links > “Use wikilinks” turned off, you can use the wikilink button for autocomplete suggestions and the links will convert to Markdown when you’re done.
You could contemplate on doing a template just to insert the “[[” to get you started, and assign that to a hotkey which is more easily accessible, possibly?
Thanks. Sounds like that would work. As a newcomer I haven’t seen a need for templates yet, and so haven’t gotten into creating templates. But I’ll keep it in mind other work arounds don’t work.
