Inline code inside numbered lists rendered as codebocks in all viewing modes when inside callouts
Screenshot which clearly showcases the issue: https://i.vgy.me/554EIS.png
The bug is present in both Live Preview and Reading mode.
When inside a callout, numbered lists that are 2 or more characters (for example 11.) indenting a bullet point and then creating an inline code inside that bullet makes all subsequent text inside that numbered list render as one codeblock.
The bug is not present on numbered lists with only 1 character (0-9).
Copy paste the following text into a new note to reproduce the bug in a fresh vault:
**Bug not present on numbered lists with one character only:**
> [!NOTE]
> > 9.  **lorem ipsum dolor sit am:** lorem ipsum dolor sit amet consectetur adipiscing elit sed do eiusmod tempor incididunt ut labore et dolore magna aliqua ut enim ad minim veniam quis nostrud.
> > 	-  lorem ipsum dolor sit amet consectetur adipiscing elit sed do eiusmod tempor incididunt ut labore et dolore magna aliqua ut enim ad minim veniam quis no: `lorem ipsum dolor sit amet, consectetur adipiscing elit sed do.`
> > 	- lorem ipsum`
**Bug present on numbered lists with 2 or more characters:**
> [!NOTE]
> > -1.  **lorem ipsum dolor sit am:** lorem ipsum dolor sit amet consectetur adipiscing elit sed do eiusmod tempor incididunt ut labore et dolore magna aliqua ut enim ad minim veniam quis nostrud.
> > 	- lorem ipsum
> [!NOTE]
> > 111.  **lorem ipsum dolor sit am:** lorem ipsum dolor sit amet consectetur adipiscing elit sed do eiusmod tempor incididunt ut labore et dolore magna aliqua ut enim ad minim veniam quis nostrud.
> > 	- lorem ipsum
Y
see screenshot
see screenshot
Obsidian version: v1.8.10
Installer version: v1.7.7
Plugins installed: 0
Plugins enabled: 0
-1 isn’t a valid list marker.
Adding 2 spaces to the indentation in the 111 example (to match the 2 extra characters in the list marker) fixes the problem.
> [!NOTE]
> > 	- lorem ipsum
I don’t remember the intricacies of Markdown list indentation beyond the basics, so I’m not sure if this is intended/correct or not.
You’re right, -1 was supposed to be 11. . I included the corrected code at the end.
Based on further testing, if you remove the callout aspect of this whole thing, the issue is present only in Reading mode, and not in Live Preview mode.
Source mode: https://i.vgy.me/R1vv9d.png
Live Preview: https://i.vgy.me/KTDbe0.png
Reading: https://i.vgy.me/Prdkbs.png
> [!NOTE]
> > 	- lorem ipsum
> [!NOTE]
> > 	- lorem ipsum
> [!NOTE]
> > 	- lorem ipsum
This is not actually a bug.
According to commonmark, the number of spaces needed to property indent is variable (and it’s quite a complex matter). You are using 1 space and 1 tab (=4 space). 5 Spaces are not enough with double digit list item under those circumstances
