I am a law student, we use indentation to structure our reports. My problem is that indenting will turn text into code blocks that do not allow formatting. I need to add links etc. to indented text but keep the text readable.
There is a community plugin that allows indenting single lines and keeping the formatting. Yet what I need is the possibility to indent full paragraphs.
Making multiple indentations possible without changing the text format e.g. through a plugin.
I use < br > but it really stops the flow. I have tried various css-Snippets, too, one from this forum. Sadly none of them worked. I am grateful for any ideas!
In general you cannot produce documents that have paragraph specific indentation in Obsidian. You need to use Word etc. This is because documents are encoded with markdown which doesnât offer paragraph indendation.
You can indent every paragraph using CSS.
.markdown-preview-view p {
text-indent: 2em;
This works in preview view (Ctrl + E or âE). Achieving this in the live preview is probably very difficult or impossible. You can use splitted view (â click the book icon) to have source and preview simultaneously. Having different styles for pdf exports is possible but difficult. This kind of work is usually done using Word.
Thank you! Maybe I donât understand what you mean, but when using bullet points and indenting, Obsidian still changes the formatting of the text to code.
This is a pretty easy fix I didnât think of! Not perfect because I jump back to the first indentation after every line break, but very workable. Thank you!
This may not be what youâre looking for but one work-around would be to write your text with your word processor app of choice and save it in the attachement folder of your vault. Then create a note and embed that file into the note (dragân drop that file into your note). This allows almost instant recall of your note in its default app for editing or just reading.
The idea is that when you are done with your note then you can left click a button (Execute Code) to convert your note to docx OR you can execute a command palette command to do the same (Execute Code, Shell Commands and Enhancing Export). Enhancing Export has âexport with previousâ command which offers nearly similar functionality as Execute Code and Shell Commands.
Thank you for the detailed replies. This might come in handy, so far I need to be able to indent AND come back to the editable notes. I continuously notice my mistakes and need to fix them
