Incomplete copy in Reading mode
  1. In Settings, disable “Show inline title” and “Show tab title bar”
  2. Open the attached test.md, which should also contain the embedded test.png
  3. Switch to Reading mode (Ctrl+E)
  4. Keep the view at the top (scroll up if necessary), so that you see the first words of the note
  5. Select all (Ctrl+A)
  6. Copy (Ctrl+C)
  7. Create a new note (Ctrl+N) with any name or open a 3rd party text editor
  8. Paste (Ctrl+V)
Y
The text is copy-pasted entirely.
The last two paragraphs are missing in the pasted text.
Obsidian 1.6.7 default clean install no plugins no nothing
Windows 10
The problem happens when copying in Obsidian, not pasting, because pasting to another app produces the same result.
Without the embedded image it works fine.
It also works fine if you scroll to the bottom before copying.
test.zip (6.4 KB)
