Kaos
1
When I switch from edit mode to read mode the yaml disappears. Or, in some cases, only some of its lines disappear.
I checked that the spaces in the yaml were correct.
I went to “settings”, “editor” and checked that “show frontmatter” is enabled.
Kaos
3
Yes, it works, thanks! But it doesn’t show me the lines with hastag, is it normal?
liam
4
Yes, that’s expected. The “#” character in YAML has special meaning and denotes a “comment.” You should remove the # symbol from any YAML values
system
Closed
5
