I have a Base in a folder that has notes further grouped by (sub)folder. This is great and works well! But I would like each grouped heading to show a count of the notes found in its respective folder.
For example, the group headings should look like this: FolderPath (# results).
This is the format I want, but obviously .length does not count results. It only counts the characters in the string that is the folder path. This was the closest I could find to counting from the Bases syntax/formula documentation.
Is it possible to count results how I want to? Thanks in advance!
Caveat: I don’t want to do anything particularly hacky.
One approach I can think of is using the Summarize function in Bases. If you already have a base that lists all notes grouped by folder and subfolder, you could, for example, summarise the file name column by counting filled cells (Filled function should be existing by default.
