Hey there! Basic question from someone just staring with Obsidian - I want to import from Roam and the instruction/direction indicates (after exporting from Roam )to:
  1. Go to “Settings” - “Vault” then click on “Choose”.
    Pick the folder you just unzipped to.
EXCEPT, when I go to my “Settings” I do not see “Vault” and therefore cannot “Choose”
What am I not understanding about this fairly simple step?
Must be a mistake in the instructions. That should be “Open the Vault picker” instead of “Settings,” represented by a little vault icon.
Yep, thanks - was looking at Very Old Help info ;-(
