Many of your settings are stored in your vault. Reinstalling can fix some problems, but it will not change anything if it is a setting inside your vault.
This looks like a potential problem with your theme. Have you tried testing with the default theme?
You should also test turning off community plugins to test if that is the cause. If you have the time, it is best to test one at a time, to try and discover which one might be causing the problem.
Some plugins and themes might still need to be adjusted and fixed since the new editor has been implemented.
