I tried to fix some links in obsidian but with no success. Apparently if I insert an image into a note with Obsidian then I can see that image on every editor, but not vice-versa.
I need to open several md notes created with Typora and MarkText into Obsidian, everything is fine but Obsidian does not read images, I can’t manually fix all links because there are too many. Here is what happen:
On Obsidian I disabled Wikilinks and set the links to “relative file path”.
Apparently Obsidian think it’s a link to a note and if I click then a new note will be created with the same name of the image in the same path.
Hope I’ve explained myself well. Thank’s for your help.
