Linux: Images and PDFs don't load if vault contains accented letters such as é (non english, non ascii, cjk, Umlauts)
Create a vault that contains a character like é
Add an image to it, doesn’t seem to matter what extension (tried both svg and png)
Click on the file inside of the vault.
You see the image displayed in the center area of the app
Broken image and error in console
Have verified. all the images are perfectly working outside of obsidian. Or in an Obsidian vault that doesn’t have that character.
I’m assuming that there’s more characters that cause this issue.
  • Operating system:
    Operating System: Garuda Linux
    KDE Plasma Version: 5.25.4
    KDE Frameworks Version: 5.97.0
    Qt Version: 5.15.5
    Kernel Version: 5.19.1-zen1-1-zen (64-bit)
    Graphics Platform: X11
    Processors: 16 × AMD Ryzen 7 3700X 8-Core Processor
    Memory: 31,3 GiB of RAM
    Graphics Processor: NVIDIA GeForce GTX 1080/PCIe/SSE2
  • Debug info:
    Obsidian version: v0.15.9
    Installer version: v0.15.6
    Operating system: #1 ZEN SMP PREEMPT_DYNAMIC Thu, 11 Aug 2022 15:22:00 +0000 5.19.1-zen1-1-zen
    Catalyst license: supporter
    Legacy editor: off
    Plugins installed: 24
    Plugins enabled: 1
    1: Excalidraw v1.7.13
(I already tested it in a fresh vault as well with no plugins. same issue)
What’s the name of the vault and the full path?
Does it happen with the appimage installer?
Does it happen if start the app with this prefix
LANG=en_US.UTF-8 From the command line?
Can you embed this image in a note? Does it work?
Can’t embed the images either:
File path:
/home/thibaultmol/Obsidian/Thibault Privé/Pasted Image 20220818183242_207.jpg
Same thing happens in the other vault:
/home/thibaultmol/Obsidian/é/
Same issue when I use the appimage version
(appimage debug info:)
	Installer version: v0.15.9
	Legacy editor: off
	Plugins enabled: 1
EDIT: how can I verify if it indeed boots with the lang option?
I did
./Obsidian-0.15.9.AppImage LANG=en_US.UTF-8
(which for me then opens the appimagelauncher, and I tell it to launch once)
You need to put lang before calling Obsidian
Same issue here: Images cannot be shown when on path with Unicode symbol (emoji/chinese character...)
I am also using KDE. I could reproduce your bug (with an é).
I tried it. With a folder called é inside the vault and the appimage. Still an issue.
Here is the output from the appimage sandbox vault:
The console error says:
GET app://local/home/wmclt/.config/obsidian/Obsidian%20Sandbox/%C3%A9/obsidian.png?1660943063136 net::ERR_FILE_NOT_FOUND
What happens if you set your system language to English and restart your computer?
We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
  • create folder with a non-ascii Unicode character (e.g. , 𡗗 or देव) in folder name
  • paste an image (jpg or png) in created folder
When clicking on the image, the image should display.
Same when linking the image (![image location]) in a note and opening preview mode.
A broken image logo is shown:
Here is a recording of the steps as executed in the test vault:
record-image-error-obsidian-2
  • Operating system: Linux KDE neon (kernel 5.15) Flatpak
  • Debug info:
	Operating system: #44~20.04.1-Ubuntu SMP Fri Jun 24 13:27:29 UTC 2022 5.15.0-41-generic
	Legacy editor: off
There is an existing bug which has been closed by the reporter even though this was not fixed: Images doesn't display
This bug is not reproducible on Windows, nor a default Ubuntu 22.04 with the Gnome desktop environment. In the link above, the reporter was also using KDE as desktop environment however.
I have only been having this bug in the past month. I am using the Flatpak distribution of the app.
Try app image. We don’t produce the flatpak.
Which filesystem do you use?
we can’t reproduce this.
Same issue with the appimage.
I believe the filesystem is part of the OS (Linux), so it should be the same in every distro.
it’s not.
Oh I see: I’m using ext4
In my case the language of my OS is already set to en_GB.UTF-8.
I switched everything to Default.UTF-8 and the problem is still there.
We can’t reproduce. But we got enough reports to believe that this is real issue. Probably an upstream electron problem with some linux setups.
So I tried reproducing it. Made a bunch of vms.
Tested by creating a folder on the desktop called ‘test vaulté’. Downloading the obsidian logo into it. And then dragging the image from inside obsidian’s left panel, to a new note.
(:white_check_mark: means It worked as intended, not reproduced)
Tested using the flatpak version:
  • :white_check_mark: Garuda dr460nized 220822
  • :white_check_mark: Manjaro kde 21.3.7-220816 linux 515
  • :white_check_mark: EndevourOS artemis neo 22.8
  • :white_check_mark: Ubuntu 22.04.1
  • :white_check_mark: Popos 22.04
  • :white_check_mark: Fedora Silverblue 36.1.5
Native package repo:
AUR (appimage version):
SO, I EVENTUALLY FOUND THE PROBLEM:
In kde plasma I set my region settings here to be Belgium English. And when I did that on my garuda vm, I managed to reproduce the issue
@zeegroen can you confirm what happens if you set those region settings back to amarican english (all of them)
Can also confirm changing the format settings on Fedora silverblue, Ubuntu and Popos (all running gnome as their desktop environment)
Changing ‘formats’ to Belgium, Germany and many more probably. Seem to cause the issue
