Image is not displayed if they are deeper than 10 folders from the vault level
  1. Create a note with embedded image in same folder with the same image;
  2. Move the folder to other folders with a total depth of 10 from the vault level;
  3. Restart Obsidian and open the note with image.
Correct display of the image embedded in the note.
The image is not displayed even if it is opened in a separate tab.
  • Operating system:
Windows 10
  • Debug info:
Obsidian version: v1.1.16
Installer version: v1.1.9
Legacy editor: off
Plugins installed: 11
Plugins enabled: 7
1: Advanced Tables v0.18.1
2: Tag Wrangler v0.5.6
3: Obsidian Functionplot v1.2.1
4: Dataview v0.5.47
5: Waypoint v1.4.0
6: Surfing v0.8.16
7: Folder Note v0.7.3
I can’t seem to reproduce this using Windows 11 (22H2) and Obsidian 1.1.16 (1.1.16). Restarted a few times and moved the “10-note” around to different folders.
Have you tried in Restricted mode?
Yes, I tried in Restricted mode, but it seems that the problem is not in community plugins. I think I have found the answer.
Windows has a character limit of for a file path of 260 characters. If I would try to create a folder with a full name of more than 260 characters, I get a message about it, but only if I’m working on my system disk.
However, if I would work on my second hard drive I can create as many folders with any names as I like and there will be no obvious errors or warnings.
I’m using my second hard drive for my vault, that’s why I could create a full path name of more than 260 characters to a file without warnings, and that’s why there was a conflict in the app.
But in another thing, when I tried to use my system drive for a vault, I got warnings in system explorer, but not in Obsidian itself, so the problem recurred.
P.S.- It’s funny that the image is displayed correctly if it has a valid name length or immediately after transferring the image to a folder with a length greater than the limit, until the application is restarted. Obsidian can display attachments with a name longer than 260 characters only if they are cached, I guess.
