I have a problem that I can’t solve. The solution may be easy, but I am new and have made many attempts without success.
I’ve created two templates: Template1 and Template2. Template1 generates a new note in which there is a button (made with the “Buttons” plugin). I want this button to perform the following steps:
- Copy the title of the current note.
- Generate a new note using Template2.
- Paste after the YAML of the note generated by Template2 the title copied in step 1. I also want the button to paste that to the end of the note.
I use the Templater, Quickadd and Buttons plugins. I have made a lot of progress in my project, but I cannot make any progress.
Can you help me? Thank you
