If I create a new note with a template and start typing, I start typing inside the properties code
I have templater installed, and I have default templates for certain folders.
If create a new note by writing the internal link to a new note and then clicking on the link, it opens the new note with the correct information obtained from the default template I selected. In my case the template consists only of properties.
However, if I start typing just after the creation of the note, without changing the position of the cursor, I write inside properties code.
I attach a gif so you can better understand the bug.
bug_creation_note_template_
I am running windows 11 and using the sandbox vault v 1.4.12
You need to send this bug report to templater.
Ok, will do. Thanks.
