I was using a new theme earlier and fortunately I liked it so much I happened to take a picture of my screen, ha…. It was split screen with another application so I cropped the photo.
Edit: removed photo since it really made the theme look different than it is. I will leave the post up though because I appreciate the help and really like this theme…
I needed to export a pdf so I switched back to my normal theme. Now I have tried every theme I have downloaded and many I haven’t and cannot find this one again. I think this was dark mode. Perhaps I accidentally updated and the theme changed. Honestly, I am not one to switch themes around, but I have been experimenting with how the various themes export PDFs so I downloaded bunch of them. Now I am lost.
If someone recognizes this theme, I would really appreciate the name of it. I should note that I had the left toolbar as well as the status bar hidden offscreen. I will delete this post after I hopefully get to the bottom of this since I am sure no one else will have this issue. I apologize to the maker of this theme. My photo and note layout doesn’t do justice. Sorry for such a stupid help request! Thanks so much!
I’m pretty sure that’s Blue Topaz.
That is it! Thanks so much!
fyi, adding a new theme doesn’t delete the old theme. You can have many installed and switch back and forth on the Settings>Appearance>Manage page.
