every time I use it, it doesn’t work and it displays like this
You have to “escape” the Tag formatting with a backslash \
This will do it: # \#Biologie
In general you can escape any kind of formatting with a backslash.
its not working
Are you really using a backslash?
Oh woops, forget about that. You are talking about the actual title of the note, not the first header. It’s not possible to use #
in your notes’ title.
yes i would like to change that
it’s good they showed me how to remove the fact that the title of the note is visible
