Disclaimer
Is this project made with AI beyond the author’s ability to comprehend how it works? Yes
It reads what you’ve connected (Obsidian, notes, camera roll) and resurfaces old pieces a few at a time in a place warmer than a terminal. Notes and photos import are Mac-only for now. You can sit with the librarian for a reflection on what has been going on recently, and it can also surface a note or photo it thinks might feel joyful or blessed to you. The Obsidian connection is direct: you point the room at your vault folder, it reads your markdown notes from there, and what comes back on the shelf is shown exactly as you wrote it.
I built it because I always experience brain fog. I can’t stop that from happening, but I wanted at least a way to see or read things that used to make me happy. I’ve used Obsidian for a while because I like the second-brain idea, and working with AI got better as it knew me more — but I’m a visual person. Skills in a terminal or code editor can be powerful, and I still wanted that warmer place, where I don’t have to keep asking it to run a certain skill. I just want the space to know I need it.
It is free: with no key, everything runs on your own machine and nothing you bring in leaves it. If you say yes to the room’s one question, it asks GitHub once a day whether a newer version exists; that request carries nothing of yours. You’ll need a local LLM set up to use it. A commercial AI API is recommended if you want blessings and reflections, and if a paid AI key already sits in your setup, the room will use it silently. Bringing things in and sorting can take an evening, or longer than a day — I can’t tell you which until it’s in it. Writing comes in first; pictures are much slower.
It doesn’t support mobile yet. On Windows you can use it with Obsidian. If you quit in the middle of a long picture import, that work is lost, so please don’t quit the room then — making an interrupted import survivable is the first thing I plan to build after launch. Sometimes it can go quiet and look stuck; it is still working, and having it say more as it goes is planned too. Machines with less than 16GB of RAM are not recommended. No support is promised.
The Study Room is the first room of a visual home I’m building for myself; I’m planning to work on the kitchen next.
Try it:
- walkthrough —
https://indoorhuman.github.io/mansfield-room-demo/ - demo room —
https://indoorhuman.github.io/mansfield-room-demo/room/ - app —
https://github.com/IndoorHuman/study-room - how it went —
https://docs.google.com/forms/d/e/1FAIpQLSfJqSJb7xO07R40lVNJDKWGEVnfEm8wDbg7jyH0Dqh86x2t9w/viewform?usp=pp_url&entry.970072248=Obsidian+forum
