Hwo to create a common card using obsidian spaced repetition
Is there any way to create a flashcard that is visible in multiple decks.
I tried with this but this flashcard is only visible in first deck not in second.
#flashcards/first
#flashcards/second
Common card
Answer for common
Can anyone help
From https://www.stephenmwangi.com/obsidian-spaced-repetition/flashcards/#decks:
#flashcards/language/words #flashcards/trivia #flashcards/learned-from-tv
A group of cats is called a::clowder
Note that as shown in the above example, all tags must be placed on the same line, separated by spaces.
