How to use vault/.obsidian.mobile/snippets css with obsidian sync?
Use main-mobile.css from my .obsidian.mobile config folder.
I have:
  1. set About ⥤ Advanced ⥤ Override config folder to .obsidian.mobile instead of the default .obsidian.
  2. turned on Sync ⥤ Vault configuration sync ⥤ Themes and Snippets
  3. restarted obsidian on mobile
None of the above gave me an option to load my own snippets in Appearance ⥤ CSS snippets. It simply says “No CSS snippets found.”
If you use separate config folders (.obsidian and .obsidian.mobile here), the snippets aren’t going to sync as they are in .obsidian/snippets/ and .obsidian.mobile/snippets/ respectively.
