Searching for current existing documentation on pdf export styling.
Adding entire css inside @media print {}
and setting up some properties that didn work.
I have tried searching export PDF select theme, and everything I found where just references to use @media print{}
, but I really have no idea of how to use css and nobody actually suggested anything on how to specify the default theme for pdf exports.
How would the .css snippet be?
Thanks for any of the help!
TLDR: Im on Linux by the way and I know some things in Obsidian get implemented later. Can that maybe the case? Because we I added things in the snippet nothing happened.
