Motivation
The native Obsidian URI is not constant regarding to any path change(s) or filename change(s).
I what to create a URI for my note that only depends on it’s UID in
UUID: {{date:YYYYMMDD}}{{time:HHmmss}}
format. (see screenshot below)
My current practice
My current practice is
- copy manually the UID of a given note
- use keyboard maestro to past
obsidian://advanced-uri?vault=Second-Brain-sync&uid=
- then
UID
Problem
Is there a way to copy the value of a specific key in YAML with shortcut ?
In my case, the key is UUID and the value (in the screenshot) is 20220103133616
