How to search parts of (nested) Tags?
I have nested Tags like #AAA, #AAAsss, #AAA/bbb, #AAA/ccc and so on
When I search for #AAA via “tag:#AAA” or just “#AAA”, I will get all sorts of results.
How can I tell Obsidian to only display “#AAA
(I think, it is not possible via regex search)
Thanks for your help!
You might check out my recent post:
Dataview Plugin Snippet Showcase (Dynamic Magic Book Catalog)
I spent a couple of (painful) days dealing with this issue, and I captured the solution that finally worked for me.
The post also summarizes some of the subtleties I found while working on the project. I hope it helps.
Just to let you all know: Regex worked for me with this:
/(^|\s)#AAA(\s|$)/
and:
/(^|\s)#AAA/(\s|$)/
