I have deleted a Vault some time ago that i did not need anymore. I also had it set up so that every time obsidian opens, it opens a specific document in said vault, but now that i deleted it i always get an error message when launching Obsidian.
This could be due to me having removed the folder within my file explorer instead of removing it in the vault list within Obsidian first, but now i cant anymore since it doesn’t show up in said list anymore.
This is not a crucial issue since it works fine after closing the error message, but its still a minor nuisance that id love to get rid of.
- Remove an old Vault File from the Registry to prevent Error Message on Startup
- Look for a config file within the executable folder of Obsidian
- Google for said config location
- Remove the Vault inside of Obsidian
- Check Options & Core Plugins
- Contemplate Life Choices
