How to query callout text inside next daily note?
Hi there, sorry for bothering you, but I have an issue.
I have a callout on my daily note like that :
[!INFO]+ Action Plan
  • Goal 1 :
  • Goal 2 :
  • Goal 3 :
It features an Action Plan for tomorrow.
On the next daily note, I have a dataview snipnet that is supposed to query this previous callout onto my new daily note. But it doesn’t work
It worked with sections, and now I’m using callouts. I don’t know what to change and I’m quite a noob. If you have any idea… I already tried using .callout instead of .section but it doesn’t work like that it seems.
[!TODO]+ Today’s Goals
TABLE WITHOUT ID L.text As "Today's Goals"
FROM "-Daily-Notes"
FLATTEN file.lists As L
WHERE meta(L.section).subpath="Action Plan" and file.name= "2023-05-02"
