I’m researching some literature that isn’t really concrete, like each book defined a very different explanation of the “topic” and each of those topics in different books has different “characteristics”.
While going through different books, it’s becoming hard to see a good relation in the graph chart about how different books defined different characteristics for a topic.
For example, imagine that in one book, there is a topic about apples, and for characteristics of apples, you can see that it’s good for the brain and stomach and bad for fingernails.
In contrast, another book talks about the apple and says that it’s good for hair, bad for the stomach, and does not cover fingernails, and says instead of apples, bananas are good for the stomach.
Now if I want to know what is good for the stomach or what banana is good for and bad, I don’t have any way to find them other than going through all the notes again. Another issue is that I can’t see what the majority of books are suggesting about apple.
Or when I look at apple, I can’t see what characteristic is related to it.
I’m trying to establish a mental model between the source (book), “explanation” and “characteristic”.
What I did
- created one folder per book,
- for each book, I’ve re-created the topics and characteristics again (48 topics and around 50 characteristics), so for each book, I’m recreating like 100 notes, let’s call them book’s note
- I also created about 100 notes as the root’s note
- then in each book’s note, I create a link to root’s notes. in this way if I go to root note, I can see under which book this topic is repeated.
Though this is working, but I have an issue; I’m creating about 100 notes per book, then I’m linking each book’s note to the root’s note. This cluttered the graph view tremendously, and I wondered if there was a better way of doing that.
I considered using tags, but tags won’t let you connect things. For example, I can’t connect #apple to #stomach and it won’t show as a connected node in the graph view.
I appreciate it if you share how you manage these not-concrete topics while one topic could have many meanings and contradictory relations and definitions.
