How to keep same padding of the next line of the bullet point?
Is there any css that can help me with this ? I’m using minimal theme.
Does it do that in the default theme? If so there may be something wrong with your text — copy it and paste it here in a code block.
If not, then yes, CSS should be able to fix it (but I don’t know enough to provide details). It’s also possible there may be a setting in the Minimal Settings or Style Settings pkugin, tho I think it’s unlikely the theme’s author would deliberately allow the format you’re seeing.
Thank you; I figured it out. A few months ago, I used CSS to have some space between bullets and text. Turning off and on the snippets helped me solve the problem.
