Since version 1.0, there is the active note name in window title. I would like to exclude this from the title, because it’s messing with a workspace manager I’m using which needs fixed windows names.
Thanks !
Thanks !
Try deactivating the option Settings > Appearance > Show inline title
I didn’t mean the inline title, I meant the title of the Obsidian’s window.
Like e.g. : If you launch notepad on Windows, the title of the window is “Untitled - Notepad”. Is it clearer ?
Settings > Appearance > Window frame style
Thanks, unfortunately all the styles include active note name in window title.
To whom it may help : Search for a plugin named “Active note to window title” by Joost Plattel. Despite the name, it also allows you to choose whatever custom title you want for the title bar ! This should be a native setting, but meanwhile it does the trick
