I install quite a few plugins, many of which add options to the right-click menu of “more options” on the right-top corner of the editor (just as you can see in the following picture). I think they cause redundancy to some extent, as I don’t use many of them that frequently, so I wonder if there is any way to remove some of the options on this menu. I do know there is a plugin called customizable menu in the community, but it doesn’t help with this. I’d like to know whether there is someone with the same feelings as me, and what you do with this. Thank you for your sharing!
