bob4
October 5, 2022, 12:30pm
1
I’ve tried to link notes and visualize them via Juggle plugin in three different ways:
inside son
note: - up [[father]]
. This works ok, create a link with up
text on it.
inside father
note: same:: [[mother]]
. This makes a link but without annotation (same
text).
inside mother
note:
down: [[son]]
This does not create a link at all.
Installed plugins:
juggl
breadcrumbs
dataview
I’d like to see annotated edges on Juggl graph for all three cases.
Is that a correct behavior or I’m missing something?
Thank you.
Emile
October 6, 2022, 7:05am
2
These should all work if you have Breadcrumbs installed. Do the links appear in your Breadcrumbs matrix? Remember that you always have to refresh the Breadcrumbs index after you add links in any Breadcrumbs format.
bob4
October 6, 2022, 7:51am
3
Emile, thank you for reply.
I have Breadcrumbs installed and the links hierarchy appears in the matrix.
Even after the index refresh, nothing changes.
Anything else I should try?
system
Closed
January 4, 2023, 7:52am
4
